Fuel smell in the 912 cabin
FUEL SMELL IN THE 1968 912 CABIN ...
I have fresh gasoline smell in the cabin while driving. I sealed the leaking fuel sending unit on top of the tank and replaced the over flow/vent hose next to the sending unit. I also replaced the filler hose coupler that connects the tank and fill pipe. Gas cap gasket is new. Where do I go from here?
Old 05-31-2023, 05:19 PM
I believe my problem is the Weber carbs. Weber doesn't use the 912 factory air cleaners. Their air cleaners allow a lot of raw gas odor to enter the engine compartment. The former owner says he didn't have the gas odor issue until he installed the Webers. Now to fabricate a mounting plate to adapt the old air cleaners to these Webers. Any good after market fuel injection kits out there?
Old 06-02-2023, 03:10 PM
Steve F's Avatar
You will have more answers on this site..............
https://www.912bbs.org/forum/
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS
Old 06-03-2023, 04:01 AM
Had webers on my ‘68 912 for over 25 years and didn’t have any fuel smell. How did you seal the fuel sender? New gasket? Take the car for a spirited drive with lots of twistiest and then take a look at the area around the sender. You’ve got to do it quick since the fuel evaporates quickly. Do you smell fuel in the engine compartment or in the trunk?
912bbs.org is a great site for 912 specific information and help. When registering I’d suggest you use a real name ( first anyway). You get better response when you do. It’s a mostly kind, close knit bbs community.
Tony
Tony
1973 914 2.2 FAT Black
1974 911 Targa Lime Green
2018 Macan GTS White
2019 Targa GTS Agate Grey
Old 06-03-2023, 06:38 AM
