pud pud is offline
Porsche 912 1969
Hi , will a mechanical fuel pump work while I have a electric fuel pump connected in the petrol line and turned off ,or would I have to remove the electric fuel pump to allow the fuel to flow ?
Old 01-12-2017, 10:59 AM
This is the set-up I'm using. Electric pump, in the smugglers box, to prime the carbs and the stock mechanical pump for running. No issues.
Tony
1973 914 2.2 FAT Black
1974 911 Targa Lime Green
2018 Macan GTS White
2019 Targa GTS Agate Grey
Old 01-12-2017, 01:39 PM
+1; a little bit different configuration. This is an old photo; I am using the setup to fuel stock Solexes (for the last 4+ years) except now I run a metal-encased fuel filter. (The wire 'hanging' by the coil powers the electric fuel pump.)
Peter
Old 01-12-2017, 04:17 PM
pud pud is offline
Thanks for the info ,
Old 01-13-2017, 03:19 AM
