Russ
Bike Rack for 69 912 Targa
Hey guys,
I thought I would share a quick build that I am working on. I am just about done with the prototype. What do you think? ![]() Thanks, Russell Last edited by Turpin; 12-28-2016 at 04:21 AM.. Reason: typo |
How is it attached to the targa bar?
Chris
1959 Auratium Green 356A Super w/ Rudge wheels 1970 Irish Green 914-6 w/2.2S Current -1967 Bahama Yellow 912 POLO 2cam4 #1 Handles like a 912 and goes like a 911 www.reSeeWorks.com |
Russ
1969 Targa Bike Rack
Chris,
I am trying to mimic the early Porsche style rack. The rack mounts with the factory location. There are two screw holes located behind the Targa seal. Thanks, Russell |
I like what you're doing, keep the updates coming !
Matt Mariani @the_r_institute Authorized Retailer FIKSE Wheels Mod Italian Wheels Maxilite classic wheels |
Russ
69 912 Targa Bike Rack
Here are some updates...
I decided to use leather straps for the rear car to mimic leather luggage straps. I think they look vintage and fit the style very good. I still have a few more items to clean up but its getting there. ![]() ![]() ![]() ![]() Thanks, Russell |
Russel, looks great.
Be careful when welding mild steel to stainless. The mig weld can and will 'pop off' if not really burned in well. May be better cut cut steel tubing in half long ways and weld it to your hub bracket, then drill through and bolt this to the rack rather than weld -Matt
Matt Mariani @the_r_institute Authorized Retailer FIKSE Wheels Mod Italian Wheels Maxilite classic wheels Last edited by Fixer; 01-09-2017 at 08:53 AM.. |
Russ
Matt,
Thank you for the "Top Tip of the Day". I did not know that there could be issues with welding SST to mild steel. I really appreciate your input. Thanks! Luckily, everything is made of 304SST. The SST bar mount is spot welded to the SST hoop bar. Then the bike front fork mount is taped for M8x10mm screws. ![]() Thank you again, Russell |
Did you change your wire spool for stn stl also?
Looks great though and I just wanted to be sure your beautiful targa would not be damaged
Matt Mariani @the_r_institute Authorized Retailer FIKSE Wheels Mod Italian Wheels Maxilite classic wheels Last edited by Fixer; 01-11-2017 at 05:41 AM.. |
