Valuation Opinions Needed..
I found a solid 1966 912 Coupe to restore. It's all there and original except the engine was replaced in the '70s by the dealership.
The engine case has no serial number above the 'MADE IN GERMANY' on the front case, just blank and smooth. This i assume means it was replaced with a new motor back then. I think this better (in terms of value/collecting) than having an engine swap with the wrong serial number. My question is; how much will this effect value? I plan on doing a thorough nut and bolt resto on this one. TIA, -Matt
Matt Mariani @the_r_institute Authorized Retailer FIKSE Wheels Mod Italian Wheels Maxilite classic wheels |
They (dealership) sometimes put the original engine number on the replacement engine. However, it is not the same as having the original engine. The price and selling of the car will reflect this. It is still a replacement engine.
You can still have a fine example of the type 912, after restoration. It would then depend on how badly someone wanted this car on what you can get for it. |
Pop over to the 912Registry and check it out. Might help you out.
"What the hell is an Aluminum Falcon??" -Palpatine (Robot Chicken) 1978 911SC Targa Working Projects: 1968 912 |
Thanks, i did the 912BBS
