-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   Cadnium Plating (http://forums.pelicanparts.com/porsche-912-technical-forum/94383-cadnium-plating.html)
cgarr 01-15-2003 04:31 PM
Cadnium Plating
Does anyone know of a good place that will process a small run (bag of nuts and bolts) cadnium plating?
Craig
atlporsche 01-16-2003 04:10 AM
doesn't eastwood have a do it at home cad plater??? or is that zinc??
plating places are dime a dozen in Livonia...let me do some looking.
where in MI are you?? I was in Ann Arbor, but worked just outside of detroit.
sjd
used to work at Roush.
cgarr 01-16-2003 06:03 AM
I am in Grand Rapids, I know there are a ton over by Detroit but who would do a hand full of parts?
Craig
bemumford 01-16-2003 11:33 AM
You might get in touch with John Twist at University Motors in Ada. John's business is British car repair and restoration, but I suspect he'd know about sources for cad plating in the Grand Rapids area.
atlporsche 01-20-2003 04:00 AM
finally got the list...give these guys a shot if you haven't found anything.
Ductile Chrome Process
Ph. 734-261-8310
Fax. 734-261-9490
Fini Finish Metal Finishing
Ph. 810-578-0050
Fax. 810-578-0054
International Hard Coating
Ph. 313-535-7210
Fax. 313-535-3220
Bellville Plating
Ph. 734-697-7000
Fax. 734-697-7023
McNichols Plating
Ph. 313-538-3470
Fax. 313-538-0025
Pioneer Metal Finishing
Ph. 734-384-9000
Fax. 734-384-9577
Alpha Metals
Ph. 734-426-2855
Fax. 734-426-2954
Associated Electro Platers
Ph. 248-547-5520
Fax. 248-547-5521
B & L Plating
Ph. 810-778-9300
Fax. 810-773-4366
Dependable Hard Chrome
Ph. 248-474-6656
Fax. 248-474-0489
