-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   front shocks (http://forums.pelicanparts.com/porsche-912-technical-forum/97003-front-shocks.html)
eki912 02-05-2003 02:22 AM
front shocks
Any special tool or trick how to open the front struts? Got them loose from the top , everything else out. Could not open the round top part which holds the shock itself inside the strut.The one with two small holes.Just brutal force and patience , OR?
e k i
eki912 02-06-2003 04:46 PM
REALLY , no one ever had this problem before? The other side.... the topmount nut is stuck too....canīt even try to open the previously mentioned insert holding round thing.The other side STILL stuck , tried all tools I have.Should I take the whole thing out?Try it in a vice?
e k i
craign 02-07-2003 12:02 PM
Eki,
I am curious about this also as I am about to do my front shocks.
You might try posting this question at
www.bay912.org or one of the regional boards there.
Craig
cgarr 02-07-2003 12:49 PM
I replaced mine and had to make a special tool to install the Koni struts, their (koni) nut had the two holes so I made a ring with two studs to fit the holes then just used a big pipe wrench on the homemade ring to tighten... to take the old apart I just also used the pipe wrench since I was not going to use again the old nuts. That top nut can turn the entire strut, you can try to hold the washer below, it has a key to fit the strut or a good air wrench will break it loose quickly. dont forget a good antifreeze mixture in the housing when you replace the strut cartridge.
Craighttp://forums.pelicanparts.com/uploads/ring.jpg
eki912 02-07-2003 07:02 PM
Nice picture! Got them both out ! With a clever and powerful friend... Had a good pipe wrench with extension to give SOME POWER , extension was about 1 meter long metal tube! Then locked the strut from turning by metalbar , strong one with holes , bolted to wheelbolts.One keeps from that metalbar , other helper opens slowly with this HUGE extended pipe wrench!With this kind of arrengement and tools , it either opens , or you will ruin the whole strut!Well both locking rings look horrible now , but I got them opened! Did not have a chance to a nice tool like that!And I am not sure if that even would have lasted , I mean these ones were stuck! I hope this is understandable.
e k i
