oil pressure pistons
I am overhauling my 2.0 914 engine and have run into a problem. In taking the oil pressure pistons from the engine the one at the flywheel end is stuck. It is a lot smaller than the other and my puller that I used for the one on the pulley end will not going to it as the puller is to big. I need to remove it as it is stuck so to be able to control the oil pressure and do not want to screw something up . Any suggestion guys
Old 07-24-2018, 01:28 PM
porschetub's Avatar
Get a piece of wood dowel ,peel it back till a tight fit,tap in with a hammer it will come out,make sure the piston isn't worn out normally that's the reason they stick,replace the spring also if you need to do the piston.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 09-01-2018, 09:36 PM
oil pressure piston
Thanks guy your way worked
Old 09-16-2018, 10:05 AM
