914 Weltmeister Front Sway Bar Install
I am installing a 19mm Weltmeister front sway bar under the gas tank. I have drilled the holes and will be welding in Brad Mayeur's reinforcement kit. I noticed that the mounting surfaces on the car are not flat enough for the reinforcement plates and that each is not necessarily parallel to the other side or perfectly perpendicular. I am concerned that the bar will not move freely in the bushings if the reinforcement plates are just welded on the flat surfaces. What have others done about the welding the flat reinforcement plates since the bottom angle is not flat on the inner fender?
Old 08-27-2018, 04:53 PM
