-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   914 Engine Rebuilding (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/1010151-914-engine-rebuilding.html)
Adidas 10-12-2018 10:38 AM
Need your 914 engine rebuilt? I can help. 914 owner and enthusiast for 38 years. Can rebuild to stock specs or larger displacements as well. Also 914 restorations as well. Thanks Bill W. 704 291 0697
LostinKY 11-18-2018 06:25 AM
2 litre head rebuild
What do you do with 2.0 heads that are on their last oversize valve guide? Mine are worn, lots of smoke on deceleration. Do you weld up the bores and ream back to OEM?
Dave at Pelican Parts 11-18-2018 07:58 PM
That's one possibility. You can also get new 2.0 castings from AMC, though I have heard that the hardware on the castings is a bit substandard.
--DD
acar24 12-21-2018 11:56 AM
I have a set of new 2.0 heads and a new set of Mahle pistons and cyls 039 198 075 euro 94mm. Thanks, LARRY
