Smoke from exhaust
Well my new motor seems to like smoking when cold and only when cold. I can't tell wether or not is is blue or white, seems to be in between. I'm running dual webers that are un-tuned. Could it just be that the carbs need to be tuned or what? I would think that the motor would burn oil when warm because it expands not the other way around. Does anyone have any insight on this matter? Thank you
Old 09-25-1999, 09:40 AM
Jim,
Actually, it is not unusual to get a little oil smoke at first startup. When the engine is setting, some oil will seep into the cylinders from the valve guides and rings if they are a little tired. Nothing to worry about.
When the engines heats up, the parts expand which actually close in the gaps. Think of a donut shaped metal piece. As it heats up it expands in ALL directions. That means that the inside diameter will get a little smaller, while the outside diameter will get a little larger. It does NOT all expand outward away from the center.
Old 09-26-1999, 03:51 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
If your car smokes out of the engine compartment (not the tailpipe), starting about 3-5 minutes after you start the engine and lasting about 5 minutes, then you have oil leaking onto the heat exchangers. The most likely suspects are the pushrod tube seals and the valve cover gaskets.
--DD
Old 09-26-1999, 10:44 PM
My motor smokes for about 10 minutes after I start it when it's cold. It comes from the inside of the exhaust so it's not oil on the heat exchangers DD.
Old 09-27-1999, 08:43 AM
