Removable Backpad to Access Engine
If you've been visiting all914.com, this issue is a rerun. But check out my removable backpad project, completed last weekend.http://forums.pelicanparts.com/uploads/fullseats.JPGhttp://forums.pelicanparts.com/uploads/hatch8.JPG
Great idea, I would have had the upholstery shop fill the hole in the top pad.
CCLinLOO |
ya what's that hole for any way?
A VW dome lite. worthless.
CCLinLOO |
That hole??
CCLinLOO |
so that's where the dome light is....I've been tryin to figure out where the dome light went but my car doesn't have one. I'll probably put it somewhere a little better than right there though.
To change a fan belt thru the dome light you would have to be a gynocologist, Craig.
Geoff |
my dome light works great.
Damn well better too, took me the better part of an afternoon to get it rewired to the doors. =-) |
Just to clarify, the little hole in the leather in the first picture is for the dome light. The large hole, (reproduced below), sealed by an aluminum panel, lined with screws, is how you access the engine compartment to change the fan belt and to manually crank the engine, using the alternator nut in order to perform a valve adjustment.
The reason why valve adjustments are such a pain in the ass in 914s is largely because its a ***** to turn the engine over manually (because the alternator pulley/crank pulley is hidden against the firewall. That's why people sometimes chip the fan trying to turn the alternator/crank pulley and that's why PP has recommended that you jack the car up and turn one of the tires while in gear. All of this is to get around the problem of hand turning the engine. Douglas http://forums.pelicanparts.com/uploads/hatch9.JPG |
James |
Speeking of that....
A gynecologist had a burning desire to change careers and become a mechanic. So he found out from the local tech college what was involved, signed up for evening classes, attended diligently, and learned all he could. When the time for the practical exam approached, the Gynecologist prepared carefully for weeks, and completed the exam with tremendous skill. When the results came back, he was surprised to find that he had obtained a mark of 150%. Fearing an error, he called the instructor and said, "I don't want to appear ungrateful for such an outstanding result, but I wondered if there had been an error which needed adjusting." The instructor said, "During the exam, you took the engine apart perfectly, which was worth 50% of the total mark. You put the engine back together again perfectly, which is also worth 50% of the mark. I gave you an extra 50% because you did all of it through the muffler. |
Ok, So you cut a hole in your firewall to do valve adjustments easier? I made a T out of a 2X4 and a 4X4 to hold one of the wheels while I turned the other one to rotate the enigne. It fits perfect between two lug bolts to hold one wheel while it is up in the air. With the marks on the flywheel I can see underneath throught the small hole in the case. Do a complete valve adjustment in about 15 minutes alone. Works great.
The wooden stilt idea sounds interesting but I'm having a hard time picturing it. Love to see photos.
Douglas |
2 nails, 1 2X4 about 2.5 feet long, and one 4X4 about 2.5 feet long. Took 2 minutes to build and works great. I feel safer with the car on Jack Stands rather than taking the chance of rolling over or off a ramp. http://forums.pelicanparts.com/uploads/stilt.jpg
All creative ideas... How 'bout one car ramp & one jack stand?
The REAL reason why valve adjustments are such a pain in the ass in 914s is largely because its a ***** to get your hand/hands inside the tin to reach the adjuster. I cut the **** out of my arms every-time. Am I tryin' 2 hard?
G |
I only put one side of the car in the air at a time.
I get to most of the valves from the rear of the rocker box area, with my arm laying on the heat exchanger. A couple I can get to from the front of the rocker box. And on one side, I can get to one or two valves directly from the side, sort of. --DD |
hey Douglas, I like it!
Here's some pics of mine. I haven't yet put a metal panel in, I have been flip-flopping between aluminum and stainless. Makes distributor work, belt change, etc... much easier! http://members.rennlist.com/mountain914/panel1.jpg http://members.rennlist.com/mountain914/panelclosed.jpg http://members.rennlist.com/mountain914/panelopen.jpg |
ROFL! Thanks man, I needed that. People with A/C could probably benefit from the extra cooling of just leaving it open, the extra heat in the winter is also a plus. M |
With that engine - Wouldn't it just suck U into the trunk? I'd hate to have that problem. he he he... Better give it to me. But on a side note; has there been structural considerations - prior to cutting a hole?
Gary '73 914-4 2.0 f.i. (wannaba6) |
Lee, a thought just occured to me, isnt it very loud in the Passangers compartment? a there is a Big opening from the 6' engine to the cabin? I think that putting a piece of aluminum over that hole with bolts (?) holding it in is a smart thing douglas. Looks good both of you.
The "Bat-door" into the engine compartment is a very interesting idea......and one that reduces the amount of time a guy spends with the rump facing the sky and legs knifed into the air like a Praying Mantis.......but one phrase has me concerned: "Cut a hole in the FIRE wall"
http://forums.pelicanparts.com/uploads/FIRE.GIF http://forums.pelicanparts.com/uploads/fire2.GIF "Is it getting warm in here or is it just me???" |
By the way......I have tons of even better pictures in the screensaver...............
I want that screan saver now, lol
Yup. As I once said to Michel Richard, "Think about the name of that panel. Firewall."
I suggest getting that metal panel in there ASAFP. A little sound-deadening stuff on the inside of it probably wouldn't hurt, either... --DD |
Yeah - it's loud... but sweet, sweet music to my ears!
Actually it's not that bad with the cushion velcro'd on. If you heard my exhaust, you would know it's just as loud with the windows down and top off. The 3.0L runs smooth as a kitten (when warm) and very little noise, other than road noise, is noticable. OK, OK - I know what a firewall is for! :p (hee hee) I have decided to go with aluminum (cost and ease) and am shopping around for some kind of dzus fasteners this spring. Should have stated 'save the safety speeches' in my post (grin)! Right now - got about 4 feet of snow outside, so I'm going nowhere! |
I found having the car on ramps, chock both front tires and jacking the drivers wheel up just high enough to get a jack stand under it does the trick for adjusting the valves. It's high for working on, easy to spin the tire with your foot for the right side valves whilst under the car... no problem-o:)
bruce |
How about this removable panel?http://forums.pelicanparts.com/uploa...h firewall.jpg
To hold the rear wheel durring a valve adjustment, I just use a rope to tie one spoke to the strut. That wood cross lookd likje the frame that I bolt to my jack pad when I remove the engine
I sure hope you guys keep a bag of marshmellows in the glove compartment.......would be a shame to waste a perfectly good opportunity for a s'more party..........
| All times are GMT -8. The time now is 08:31 AM. |
