Scott S's Avatar
Oil Level Help
Hi All -
I have just finished a front oil cooler install with t-stat. When the engine is running the engine oil level reads perfect on the dipstick. When it is shut down and has cooled off it reads probably 3/4 of an inch over the full mark on the dipstick. Should I make it so it reads correctly running or not running? We have been having some discussions on the colorado 914 board - just thought I would get a broad range of views.
Thanks!
Scott S
- A pile of British stuff
- A growing pile of German stuff
... oh, and two Hondas - complete with car seats and pounds of fish crackers smashed into the carpet (and seats, and door pockets, etc etc etc....)
Old 03-12-2003, 11:07 AM
evill's Avatar
Scott, BTDT. I was overfilling my oil by checking it with the engine running. I now warm the engine and then check the level. Check it hot right after you shut it down. It should be at the top mark. If you let it sit a long time, the oil from the upper parts of the engine and case walls drains down to the sump, showing a higher level. The oil from the cooler and lines can also slowly drain back raising the level.
Ed
Basically, I'm One Giant Train Wreck.
http://community.webshots.com/user/evill914
Old 03-12-2003, 11:12 AM
John Rogers's Avatar
If the engine is a dry sump engine either a 6 or a 4 then you should check the oil with the engine warm, level and running. If it is a wet sump engine even with a front oil cooler then warm the engine, shut it off and check quickly as Ed said. Normally dry sump engines are level checked at the tank, not the block as the oil is getting sucked out as fast as possible. Good luck.
Old 03-12-2003, 11:39 AM
