Potter's Avatar
Send a message via AIM to Potter
Angry Loose Windows
It seems that the angle of both my passenger and driver side windows is off just slightly.....such that when I close the doors they do not match-up tight with the top seal. Thus, in the rain the water rolls right into the interior. Obviously I avoid this.
Is there an adjustment that one can do to have the glass angle IN slightly more so that there is a reasonably tight match to the seal when closed? I have been hesitant to experiment just cuz it is glass and I am both a klutz and an idiot.
'73 914 2.0
"Seriously Honey, the part was really really cheap...........honestly"
Old 03-12-2003, 06:44 PM
John Rogers's Avatar
Windows are easily adjusted. The best thing to do is take the panel off to see the mounting bolts and screws and then loosen them and move things around to see what happens. The windows can be adjusted in/out at the top and the anglge of the top glass edge can be adjusted. Make a drawing and take some notes as the Haynes manual is okay for pictures but not much about adjustments. Make sure the door jams at the rear are lined up and that the car is not sagging any? Good luck.
Old 03-12-2003, 08:45 PM
Potter's Avatar
Thanks John.....with that I now have the confidence to take a stab at it.
'73 914 2.0
Old 03-13-2003, 03:44 PM
