Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 914 & 914-6 Technical Forum
Flat4ever's Avatar
Engine mount bar screw
Hello,
I would like to know the specification of the engine mount bar (73 + / side shifter) screws. Lenght, diameter, head, resistance. Metric units welcome
The thread of mine has been strongly damaged, but I am not sure that it was an OEM one ... Thanx for answers
Old 03-18-2003, 04:24 AM
Jim Smolka's Avatar
If my memory is working, it is a grade 8.8 steel bolt. 10 mm. You could install a 12.9 steel bolt in its place
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 03-18-2003, 04:30 AM
Never left, but not right
Zeke's Avatar
Flat, you can read on the head of the bolt what it is. 8.8 is the lowest grade, apparently = to grade 5 SAE. I will get criticism for this, but I have replaced many of my thru bolts with Grade 8 SAE. This is due largely to the fact that metrics in the higher grades are scarce and expensive. In my case, a 3/8" bolt substituted for the 10mm just fine. I'll just have to remember to carry a set of stadard wrenches and sockets under there with me as well as metric. It's kinda like my Chevy truck. Half metric and half SAE. Hah!
Old 03-18-2003, 07:14 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Personally, I prefer to keep the fasteners metric on my cars. But unfortunately, some aftermarket companies (like Weltmeister) have followed Zeke's reasoning, so I have a few SAE fasteners on my poor lil' 914...
Iffin I were at home, I could look up the length of the M10 bolt for ya. Or you could measure it... (The length that you would buy does not include the bolt head.) Also try to get something with the same amount of thread, or a little more, rather than threaded the whole way. They should be stronger that way.
And remember that the nut that goes on that bolt is self-locking. I don't remember if Nyloc was originally used, but it works just fine for this application.
--DD
Old 03-18-2003, 07:21 AM
Jim Smolka's Avatar
If I put SAE nuts and bolts on my car, will it go slower???
'81 SC 3.6 (Beast)
Old 03-18-2003, 08:20 AM
Zeke's Avatar
Oh, if it's the length he wanted, it's 3 1/2" I thought he had the one sample.
Old 03-18-2003, 10:50 AM
Administrator
3.5" * (25.4mm/") = 89.9mm ...
So that would make it an M10x90 bolt. Sounds about right. I recall that it has a 17mm head. Uhh, I think.
--DD
Old 03-18-2003, 01:40 PM
yoh!!!'s Avatar
Zeke... 8.8 is not the lowest grade in the metric DIN system. There is 4.x (most of the time 4.6) and possibly softer steel than that. 8.8 is pretty much the middle of the road quality ... used for most automotive applications. 10.9 and 12.9 is the tough stuff.
'74 Porsche 914 2.0l
'90 VW Vanagon 1.7l Diesel
Old 03-18-2003, 02:44 PM
Zeke's Avatar
Whatever. I guess I meant in the context of automobile fasteners. I've not run into any 4.anything. To me, that would be gate hardware. But, thanks for the info.
Old 03-18-2003, 03:19 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
