-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Head CC Question (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/103127-head-cc-question.html)
1bad914 03-21-2003 12:30 PM
Head CC Question
I just cc'ed my 914 2.0 heads. They seemed large 57! Is this close to what others have gotten, I just got the heads back from RIMCO. Just curious if I'm in the ballpark!
Randy
mike95125 03-21-2003 01:33 PM
you can use some of the formulas on this page to figure out if you have the right compression ratio.
www.bgsoflex.com/auto.html
Dave at Pelican Parts 03-21-2003 02:03 PM
57cc seems about reasonable. I think mine were 58cc, and Jim Thorusen measured his at 60cc.
--DD
Zeke 03-21-2003 03:17 PM
And mine are 53cc with a .040 deck. I calc'd that out to 9.5 or so. Let me know if that does or does not work out for you mathematically. Oh, and 96mm on the pistons.
CGNJ 03-21-2003 04:24 PM
Hi,
Mine were 60cc. Possible that your heads have been flycut?
CGNJ
1bad914 03-21-2003 05:15 PM
Yes, RIMCO calls it surfaced, but I call it flycut. Zeke, 9.5 is correct for your specs. I'm just used to VW hi-po heads that are usually in the low 50's. They actually measured close to 58. I'll set deck height tomorrow.
Thanks!
yoh!!! 03-21-2003 07:55 PM
Same here, 58 ccm after a mild flycut on my heads...
Patrick
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
