-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   O ring Location (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/1034441-o-ring-location.html)
vlindell 07-11-2019 10:29 AM
O ring Location
I am replacing the selector rod seal on my 1973 2.0. #12 on the diagram. I also want to replace the large O ring that surrounds the entire selector mechanism. I am having difficulty identifying where this O ring is located. Is it #20? If so I am not sure where it is to be seated.
http://forums.pelicanparts.com/uploa...1562869726.png
jess p 07-11-2019 06:32 PM
That round o-ring #20 fits around a groove at the base of where #10 fits into the transaxle. Look at the picture at #20. Now look just below it, imagine it being lowered onto the housing. If you can’t visualize it I can send you a pic of mine.
I should mention that to properly rebuild that assembly you need to remove pin #16 and /or #19 to properly install all the seals. Message me and I can e-mail you a pic. I’m in the process of rebuilding my 73 trans as well
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
