Throttle valve housing - rebuild or replace?
Car is a 912 E
Throttle sticks at wide open throttle. First half of pedal travel is fine. As soon as I floor it, the throttle sticks, and pulling the pedal back up will not help. I removed the boot, sprayed/wiped down venturi with carb cleaner, trimmed the crimped end of the cable, and soaked with Kroil and PB Blaster. Even with the cable removed, I could still feel binding on the butterfly shaft. Anyone have a part number for the whole assembly - they don't look too expensive, and if replaced, I would always have a back-up ready to go. Thanks in advance, Bill K |
Hey Dave, are you there....
I think I have the PN ...039 133 062 D ? Thanks Bill K |
That's what my copy of the PET says for the 914. I don't know if the 912E throttle body is any different. It looks the same, but that doesn't always mean it is identical.
--DD |
you will have to get yours rebuilt, 912e throttle bodies are impossible to find
Right you are Dr.
The pn of the original is 022 133 067 A - not listed anywhere anymore. The 914 replacement unit (039 133 062 D) will probably bolt up, but I don't think the throttle venturis will match up. The oem unit is as follows: top - 58.82 mm bottom - 57.65 mm butterfly - 45 mm Bill K http://forums.pelicanparts.com/uploa...1565028655.jpg http://forums.pelicanparts.com/uploa...1565028696.jpg http://forums.pelicanparts.com/uploa...1565028762.jpg |
| All times are GMT -8. The time now is 04:25 AM. |
