cycling has-been
What size is this fuel line hose?
Crossover line, supplying fuel from the left-side bank of injectors to the right side.
The fuel hose is braided, and runs through a flex plastic jacket that is threaded across the top of the engine. Right side starts to weep as soon as I fire it up, and continues until the system is de-pressurized. I'm just looking to replace the braided hose. Thanks in advance. Bill K Right side (912E) ![]() Left side ![]() Grey jacket threaded over/under.
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 08-06-2019 at 06:11 PM.. |
![]() This is a 7.5 x 13 Fuel Injection Hose, and you can buy this from our host in small quantities. I offer this if you want in E-85 Rated hose. It is for the 912e..... ![]() and the hose shown in the middle of the photo is is the same as used with your 914 on the motor. Len.Cummings at verizon.net
cycling has-been
Thanks Len.
Good info. I think I have one coming in tomorrow from a local VW Hot Rod shop. Mine would be the third from the top? Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
![]() Yes, the longer one with Norma clamps at each end. Len
cycling has-been
Len, I'll take the hose.
PM sent Thanks Bill K
cycling has-been
Len, clear some of your old PM's out - no room left.
Bill K
cycling has-been
Len, did you get my email?
Please add two of the correct FI hose clamps to the order. Thanks, Bill K
![]() Yes Bill, ![]() .....packed & will be shipped this morning. Len.Cummings at verizon.net
