-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   intermittent starting seems fixed (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/1041246-intermittent-starting-seems-fixed.html)
brcacti 09-28-2019 07:20 AM
Thanks to someone very helpful, it seems sanding the ground from the battery to the body seemed to fix my intermittent starting problems.
brcacti 10-31-2019 04:00 PM
INTERMITENT starting problem is back sanded battery ground connection, replaced and clean connections to trans/body braided ground strap, cleaned solenoid connections and coil connections what would be next thing to try?
