-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   blocking up 914 (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/1047699-blocking-up-914-a.html)
Randy B 12-16-2019 07:45 PM
blocking up 914
whats the best way to get my 914 off the ground where are good lift points? getting ready to pull engine.
infraredcalvin 12-16-2019 08:34 PM
the circled areas can be used for jack stands, any of the elongated ovals should have the load spread across the whole area, with a 2x4 or other.
http://forums.pelicanparts.com/uploa...1576557240.jpg
Please be safe when crawling under the car.
Dmitry at Pelican Parts 12-17-2019 01:18 PM
Check out the below thread as well. In addition to the above member, Dave at Pelican Parts is very knowledgeable about all things 914s.
http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/62719-floor-jack-where-lift.html
Randy B 12-18-2019 08:41 PM
Thank you! Just what i needed to know
Emo993 12-19-2019 03:38 AM
I welded up a dolly to roll around. front in on the donuts and rear is on the engine mounts so rear donut rust could be addressed. Best, Markhttp://forums.pelicanparts.com/uploa...1576755452.jpg
Tobra 12-19-2019 07:17 PM
That is a nifty little cart, scissor lift is pretty neato too. I bet you could get the drivetrain in and out of that car lickety split.
Emo993 12-20-2019 03:29 PM
Well....we will find out. The engine and trans has been out of the car for 30 years. Now a 2.2L E six with S pistons, PMO's, Mod-Solex cams. Should be back in the car in a few months. best, Mark
Emo993 12-21-2019 04:23 AM
Randy B, you can also build a wood crib type dolly. Works well and holds car up along the "longs". Great engine access.http://forums.pelicanparts.com/uploa...1576930979.jpg
