BARRY MISHLER's Avatar
engine in & running
with the engine in it sets a little lower in the rear, does the front look to high?
Old 10-18-2003, 06:26 PM
John Rogers's Avatar
Really nice looking car!! Could be a little high but I'd drive it some first to let everything settle down. I measure my cars from the floor to the bottom of the heater channels front and rear to see how much it is up or down. Make sure the floor is level and then adjust the bolts at the torsion bars in front and don't forget an alignment might be needed afterwards.
Old 10-18-2003, 06:58 PM
skline's Avatar
I think the front looks a little high, but I like mine really low.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 10-18-2003, 08:58 PM
D7N7MASTER's Avatar
Talking
I believe that the "stock" setting for the front suspension causes the car to appear squat in the back. As if it were leaning backwards. I offset the stock torsion bar setting by one (1) spline, then re-adjusted the torsion bar caps back to the middle of the adjustment. Final adjust each side for ride height. Check alignment. Front now sits about two inches lower and still has decent travel. Looks much cooler with the front dam near the ground...
www.pelicanparts.com/gallery/d7n7master
Old 10-19-2003, 07:39 AM
