-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Input shaft seal (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/1056263-input-shaft-seal.html)
pnikas 03-28-2020 03:04 PM
Input shaft seal
Hello everybody , I am going to refresh a 914 gearbox . I have a new old stock seal (blue one ) that is 22/40/ 13/16
I compared it to a old genuine vw one and the seem identical . The seal it self is kind of hard . Are they generally like this or might it be bad due to being in a drawer for many years .
I saw that these seals are the best to install instead of the vw replacements .
pnikas 03-28-2020 03:13 PM
http://forums.pelicanparts.com/uploa...1585433479.JPG
stownsen914 03-28-2020 03:49 PM
Don't use an old, hard seal for the input shaft. The risk you run is oiling your clutch if it leaks, which is a pain in the butt and ruins organic clutch disks. Seals are cheap in comparison.
Scott
pnikas 03-28-2020 04:18 PM
Scott
Should I use a VW type seal? I have heard of people having issues with them.
Look it isn't exactly hard or brittle, it is just a bit harder than what I had in mind
jess p 03-30-2020 07:15 PM
The one you want is 113-311-113-B from our host. The inner portion should be soft and easy to depress.
kevingross 04-03-2020 07:08 AM
Yup. And remember to pack the seal with grease before installing. This will help to make sure you don't lose its gaiter while installing: the spring that is conspicuously absent from the black seal in your photo. Smear a little grease on the outside as well, it will make installation easier, less risk of tearing.
