-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Help needed 914 gearbox mixed the fork balls (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/1056457-help-needed-914-gearbox-mixed-fork-balls.html)
pnikas 03-30-2020 01:30 PM
Hello everybody. I was pulling apart my 914 gearbox because the main shaft bearing at the intermediate plate got destroyed . While I removed the stacks from the intermediate plate the bearing fell into pieces , as did the spring loaded bals for the forks . Of course I can’t understand which ones are the fork balls and which are from the bearing .
jess p 03-30-2020 07:24 PM
Those intermediate ball bearings measure 0.315 in. In diameter. If you measure the peanut shaped ball in the shift fork assembly that diameter will be the same as the ball bearing (spherical) in the shift fork.
