How big of an engine can run on Factory FI
How big of a four cylinder 914 engine can be run with a factory 2.0 liter D-Jetronic system and what modifications are needed to run a larger engine?
2056cc is pretty easy. It can take some tweaking of the system to make it work well, and those adjustments (especially of the MPS) can be very fiddly. I haven't heard of people going any larger than that with D-jet in quite a while. There are reports of people running up to 2.5 liters with D-jet, but I would be very cautious of that and probably would want to spend some real quality time with a Wide-Band O2 meter to make sure the mixture isn't going crazy.
D-jet is not the most easily tuned system out there, so it can be a challenge for it to run well on anything but a totally-stock motor. --DD |
can the same be done with 1.8 liter, or?
Do you mean putting the 1.8's L-jet onto a 2056cc motor, or do you mean putting D-jet onto a 1.8 motor?
Supposedly the 1.8's L-jet can handle 2056cc fine. I would want to make sure that it doesn't go lean at high RPM and throttle settings, so a Wide-Band O2 meter I think would be a must. D-jet can be used on a 1.8 motor. It might take some tweaks; the 1.8 will flow slightly more air for a given RPM and throttle setting, but extract less power due to lower compression. --DD |
| All times are GMT -8. The time now is 01:48 PM. |
