Source of long 14 mm Fuchs style wheel bolts with spacer
I have a 5 bolt conversion on the front of my 1975 914, I think the PO said 911 parts. He used 1/2" wheel spacers and screw-in studs with no flange on the back. One stud was missing when I got the car, and I've read they have a reputation for backing out. I don't like these studs and can't use flanges ones like those on the back because the hub is not flat. Just saw a comment from Dave D about spot-facing, but would first like to know if longer bolts are available before exploring that idea further.
I tried to find longer bolts with the Fuchs rounded seat, but could not find any long enough in the searching I did. I recently read that the 914-6 had spacer plates, don't recall source. So that implies that longer bolts are out there, or there is another good solution.
Anybody know what I can do here?
Thanks,
Chuck
Picked up and fixing neglected 1975 914 with Buick V6
Old 05-16-2020, 06:35 AM
djpateman's Avatar
The 911 and 914/6 used hubs with studs. Hubs used with spacers needed longer studs. Not a good idea to try and find longer bolts.
Keeper of 911, 912 & 914 databases Kardex source
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 05-21-2020, 08:30 AM
dr914 ***********
the 914 alloy lug bolts have 40mm of shank, the screw in studs are only about an inch of thread once screwed in
Old 05-28-2020, 11:24 AM
