Question high idle
73,2.0 FI idle is high,1500. My mechanic but in a 911 cold start valve in place of a 914 which was kaput. He also said that maybe I have a worn throttle body which is drawing air. Any thoughts. If I jab the throttle after warm up the idle drops to 1000, which is what I had before. What is the norm for a 914- 700? Greg
Old 04-22-2003, 06:45 PM
John Rogers's Avatar
The idle should be high when cold due to the AAR valve and then drop off. I have seen some that do not slow down on their own like yours but usually they should drop off. Try the carb cleaner spray around all the hoses trick to see if there are any vac leaks. Good luck.
Old 04-22-2003, 06:56 PM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
See if you can get the AAR valve back. They usually just get stuck so you spray PB Blaster in to them and free them up.
Plug the AAR hoses and see what your idle is. If its at 1500 its vacuum leaks or mis timed.
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 04-22-2003, 07:10 PM
