Porsche Crest Help! Hot stalling question
Here is my problem – I have a ‘73’ 1.7 that I have had for a little over a year. It was in the body shop getting “un-rusted” all of last summer so I was not able to drive it. After getting my baby done, I would drive the car and after 15min, it would idle down and stop. This would mostly happen when I was in neutral coming to a stop at an intersection – go figure??? I took the car to Blagoi’s here in Columbus (great place) to get a tune up, hoping they could find the problem. No luck. It was idling at the correct RPM, but would die on me like before. I had the car towed back and Blagoi thought the problem was the pressure sensor. I put another sensor in and the car did the same thing. The car’s idle was set around 2,000 RPM’s and would stay running until the engine got hot(she did run longer at the higher RPM). I took the car out last night and drove her for about 45 minutes and she then stopped – at a traffic light! Took about two minutes to get the engine running again. Engine was cranking but seemed not to want to start until I would pump the gas. Any ideas?
Jon
Jon
Columbus, Ohio
73 914 1.7
Old 04-16-2003, 09:52 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Head temp sensor. If it gets unplugged, you wind up with very similar symptoms.
General--check all the wires and hoses. Make sure they're plugged in solid, the hoses don't leak, and so on. Verify the basic engine function (valve adjustment, compression test) and the ignition system. Then start checking FI components.
--DD
Old 04-16-2003, 12:28 PM
chrisreale's Avatar
Check your Cylinder Head temp sensor, the thing above #3 spark plug. Could be disconnected, or a bad unit. Careful removal is critical, because its easy to strip the hole. Look at pbanders site regarding testing the CHT
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/
www.914club.com
BillySpaceman's Avatar
So odd, I had the same thing happen to me. Mine is a vacuum leak and replacing the hoses has pretty much cured it. I still need a tune up though. My car currently idiles at below 1000.
"Sometimes you are the windshield, sometimes you are the bug."
2000 VW Jetta VR6
1989 BMW 325i with premium broken speaker package
1973 Porsche 914 1.7 SOLD
Old 04-16-2003, 01:32 PM
