Rob914's Avatar
Send a message via AIM to Rob914
Thumbs up Battery tray rust finally repaired!
After a year of putting it off, i finally got it done. For a year i drove around with a hole the size of my fist in the side of my car, with my battery jarred into the side of my car with a new battery tray, but i finally got it all cleaned up and welded together.
what do you think of it, it cost me $250 and a day sunny day with out the 914
http://www.pelicanparts.com/gallery/Rob914/
76 914
Old 04-16-2003, 04:40 PM
Jim Smolka's Avatar
Glad that you are having fun with your car.
Interested in what exactly was done. Looks like you still have some rusty metal btwn the drain pipe and the trunk.
If your car sees rain, check out the Optima 'dry' type battery.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 04-16-2003, 06:36 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Do your engine a favor and ditch that sound pad on the firewall. With it sagging like that, it will block the flow of cooling air into the fan... Not good. It's also very good at holding water (often with just a little battery acid!) against the firewall. Also not good.
--DD
Old 04-17-2003, 09:21 AM
Rob914's Avatar
actually i just tore it out right after i took this picture, other than insulating noise is there any other purpose for this pad?
76 914
Old 04-17-2003, 10:27 AM
Noise and heat noise insulation. Oh and it covers up the rust that may have formed on the wall, and the old dried contact glue, and the holes which may have been drilled into the firewall for non-stock accessories.
Mike
Old 04-17-2003, 11:32 AM
korijo's Avatar
Is that the "before" pic? JK
Dave
Korijo
73 Olympic Blue 914 1.7L (2L /4 back in progress)
69 Highlander Bug 1776
93 GL EV 2.8L The Van
914club.com Member #914
Old 04-17-2003, 12:38 PM
