loose shifter (spins around)
I have a strange one, that I cannot seem to find in the archives when I search. The actual shift rod (that is connected to the shift knob - yep, right there in cockpit) moves around within the shift mechanism base. It is apparent that the previous owner has JB welded it together in the past. I am confused as there is no apparent way of affixing this in place, no set screw, pins, or anything. It just spins around at the base, and is impossible to shift in this current condition...
Any thoughts? My current plan is to weld it, or chemically weld it, but wondering if there is a better way...
Thanks in advance!
http://www.waterwagens.com - September 1st, 2003
Old 04-19-2003, 02:09 PM
WOODPIE's Avatar
There are probably more professional fixes for this, but I'm a big fan of JB Weld myself. Roughed up and cleaned up the surfaces, and stuck it back in there. Has held tight for years now. Others with better methods of repair, chime in!
Ed
Old 04-19-2003, 03:50 PM
John Rogers's Avatar
I'd try to find another one if possible. If you repair it, we all KNOW EXACTLY when it will break!? Kenny Powell in Chula Vista might have one or some of the other folks here that work on them a lot?? Good luck.
Old 04-19-2003, 04:59 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
I think that one of the short shift kits has you cut and epoxy the gear shift lever. This might be the end result of that...
You can also go for welding or get another shift lever.
--DD
Old 04-19-2003, 05:02 PM
canna change law physics
red-beard's Avatar
I just bought a shifter on evil bay for $10. So they are around, rather cheaply.
James
James
Red-beard for President, 2020
Old 04-19-2003, 05:14 PM
JWest's Avatar
Actually, it was the factory that did this epoxy job. It is hard to believe, but the factory actually glued the shifter together.
You might want to just get some good epoxy and re-glue it, as another used shifter may be ready to do the same thing.
James
JWest Engineering
Old 04-19-2003, 08:20 PM
wow, I had no idea that was how the factory did it....if that is true, I guess I will just glue it back with something....lasted 30 years the first time....
Old 04-20-2003, 08:46 PM
Kenny Powell's Avatar
I think I would weld it correctly or buy a good used shifter? or if you trust it Epoxy. It's your call!
75' 2.0 w Ljet
"I like the way she doesn't move in the curve's... and then she let's go!"
Old 04-22-2003, 07:58 AM
chibone_914's Avatar
The lever came off in my hand, thankfully this happened in the driveway. I broke out my handy welder and welded a bead all around it.
Thank you!
John
johnechi@hotmail.com
Old 04-22-2003, 09:30 AM
Otto's Avatar
I had shift rod come out in the middle of a heated gt-2 scca race national. I carry a spare welded shifter so those teeners at the track will already be covered. This is a good thing to do to all the teeners shift levers, it can be done in the car, if you are willing to take the chance that some slag might hit the GAS LINES directly under the shift lever.
Racing Porsche for over 30 years.
http://www.OttosVenice.com
Check out the Porsche Owners Club Track event Videos
Old 04-22-2003, 04:41 PM
