Carbs on a 2.0L
I am looking at purchasing a 2.0l for my car. I have dual 40mm delortos that I would like to put on the engine. Will that work fine or should I look at larger carbs. I already have the carbs on my 1.8 so i would get the new intake manifold and go from there if these will be fine. any advice?
Curt
Old 04-11-2003, 06:05 PM
Amark's Avatar
I have DRLA 40's on a 2.0 and they work fine. I think the consensus is that Dell 40's or Weber 44's are similar. You might want to look at your existing manifolds some of them are drilled w/ both sets of flange holes ( 3 bolt/4bolt ).
Mark
73 2.0
Old 04-11-2003, 07:49 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
They will work no problem. We can supply the Manifolds just give a call or email to us here at Pelican. Steve
Old 04-12-2003, 08:03 AM
I used Weber 40 IDF's for many years and was generally happy with them. I got good gas mileage, though not as good as FI, and performance with a mildly tuned 2.0L. Most people say Dells work better than Webers so you should do fine. Just get the venturis and jetting dialed in and they will work well.
Mike
Old 04-12-2003, 11:53 AM
I have 40 dells on a 2.0. Run great and sound better. Just got the car in November, and took apart the carbs. The Dell book by the CB Performance guys is helpful. Parts are sometimes hard to find. I needed a secondary venturi, and the only place that had it was a shop in Italy. It took me months to find it. Here are the parts places that were helpful:
CB Performance
Art Thraen at Air Cooled Engineering 801-943-1234
You can try Matt Cooper at Euro-Carb in the United kingdom, 011-44-118-943-1180
Italy: Gabriele at AlfaRomeo1750@libero.it
John C. at aircooled.net
Old 04-14-2003, 08:40 PM
skline's Avatar
I have a set of the 40 Dells and I got the kits from a guy in Germany who I found on Ebay. Recently I found a guy in LA that knows them in and out. I also recently bought a set of 44 Weber's to install because I could not get the dells to adjust right. They just kept dumping fuel into the cylinders. He told me that they have a common problem after years of use where they have to drill out two caps on the side and reseal them. He wants $100.00 to do this to both carbs. As for parts, they are hard to find. If anyone needs the name of that shop in LA let me know.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 04-22-2003, 06:15 AM
Not right in the head
nutzforporsche's Avatar
Send a message via Yahoo to nutzforporsche
I personally didn't have much fun with carbs or luck for that matter. They don't seem to like the F.I cam. If that was switched out then I'm sure carbs would be great.
stevethacker@earthlink.net
87' 944S
99' BMW 740iL
Old 04-22-2003, 10:14 AM
bludden's Avatar
My car was described to be by the PO as having a Hi Perf cam for the stock FI, but he went back to carbs after some unknown problems. It idles a bit rough but feels like a bit more than stock HP. And the sound is great.
I did break down and have the linkage and carbs (Weber 40 IDFs) adjusted by a professional - 60 bucks well spent. Only issue I see is that with no throttle and a relatively hard corner the engine can bottom out and stall.
Brian Ludden
Charlotte NC
'76 914
2k2 VW New Beetle Turbo S
Old 04-23-2003, 10:11 AM
