woodman's Avatar
engine assembly lube
What would you guys recommend to use as a lube for engine assembly if the engine won't be started for a period of a month or two? If the typical motor oil mix (heavy weight) is used will cling to the parts long enough?
'75 1.8 -->1911
Old 04-24-2003, 09:13 AM
jamcleod's Avatar
Send a message via AIM to jamcleod
i used an assembly lube purchased at an auto parts store that was thick and clearish-red colored and was labeled as assembly lube. i've heard that an engine builder has his own formula that included a mix of motor oil and STP. i didn't store my engine for a long time.
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 04-24-2003, 09:26 AM
I've used motor oil, white lithium grease and a purchased assembly lube. I like the assembly lube the most. I friend of mine uses one that is as thick as toothpaste, he loves it. He bought it from a motorcycle shop. Really thick, but it supposedly broke down easily once under use.
Randy
2011 Chevy Silverado (The Hauler)
1984 911 Carrera summer daily driver
Old 04-24-2003, 09:46 AM
