calbrat's Avatar
headlight no move
One of my headlights doesn't pop up anymore. I have to turn the black knob on back of the light and that will get it up manually but I'll tell you what, I hate opening the trunk to pull up the light. I don't see anything disconnected. Wha t should I look for?
Old 05-01-2003, 08:01 AM
Inside the trunk, inboard or the light there is a sorta triangle shaped black cover. Under it you will find the same type relay used all over the car. Clean the terminals, try it. If that doesn't work, swap it with one that you know works (the other head light). That should do it.
Good luck
Eric
Eric
'76 914-6 2.7 Auto-x Toy
'70 914-6 Orig., in resto
Old 05-01-2003, 09:54 AM
