Question HELP - Fittings for New Dansk 914 Fuel Tank?
I just received my new Dansk 91420101012 fuel tank. I went to the auto parts stores in town looking for fittings to connect my 3/8" fuel pump line. None of the shops could figure out what fittings are on the bottom of the new Dansk tank. I have searched the forum but cannot find this info. Can one of you who has done this tell me what fittings you used?
Old 11-15-2020, 06:53 PM
Did you keep the two connections from your old tank. The fuel lines are not 3/8. AutoAlanta sells those fittings. If you still have trouble on the fittings and size I would ask Dr 914. 800-792-4944
Old 11-19-2020, 06:58 PM
dr914 ***********
also make sure that you have received the correct tank, there are two different ones that difference being the brackets on the top for the expansion tank and charcoal cannister. The early dansk manufacture did not have the correct brackets on them!
Old 11-20-2020, 07:18 AM
Emo993's Avatar
+1 dr914, my tank didn't fit worth a cr##p. Just kidding, everyone have a safe holiday. Mark
1974, 914-6 GT Tribute
2007 Cayman S
1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten.
2017 Golf Sportwagon 4motion
Exclusive source for the 914 Umbrella and Service cover
Old 11-20-2020, 11:05 AM
jess p Yes, I kept them. I had seen a thread that talked about having to use a different fitting than the factory original due to a bevel on the inside of the port on the tank. I may try to use the original supply side to see if it will work without leaking if I do not heard back about something better. Also looking also to cap off/plug the return port as I will not be using it. Thanks
Old 11-20-2020, 05:14 PM
dr914
Hi, I ordered the Dansk tank without the mount for the canister as I will not be using it with the carbs. Thanks.
Old 11-20-2020, 05:15 PM
emo993,
Than is a nice looking tank for my next 914 project car, what is it? Thanks.
Old 11-20-2020, 05:18 PM
Emo993's Avatar
Its just a Porsche 356 reproduction tank. Plans where to put in a fuel cell and then just did this. Mark
2007 Cayman S
Old 11-21-2020, 05:18 AM
Going faster all the time
Litesonic's Avatar
I, too, kept the fittings from the "early" tank. As the tank I received was the later model.
I put in new fuel line, filters (inside and the usual outside of the tank) and went stainless for the tunnel.
Now: 1997 German-built Boxster - Black
Then: (2) 1973 914 2.0 Marathon Blue | 1986 944T Alpine White | 2004 40th AE 911(996) #898 | 1987 944 Guards Red | 1976 914 2.0 Summer Yellow | 1974 914 2.0 Light Ivory | 1986 944T Black | 2006 Cayenne Turbo S - Titanium Gray
Old 11-22-2020, 06:57 PM
Litesonic, Thanks, I thought I had read that the fitting was different and required a different fitting, My takeaway from your note is that the original fittings will work. Thank you,
Jeff
Old 11-23-2020, 07:03 PM
Tags
dansk 914 fuel tank
