74 Oil Temp Sender & Gauge
My gauge needle moves slightly when the ignition is turned on but no longer moves when the engine warms up. Any thoughts is the sending unit dead or a wiring issue?
Could be either, but the sending units are known failure points. 5 or 6 bucks to replace is a good place to start.
Tony G 2000 Boxster S |
Ground the wire at the sender. It should peg the gauge. Test the resistance of the sender cold then warm it with a heat gun and it should decrease in resistance. The wire from the sender to the harness is a green wire that connects into the main harness on the passenger side.It could be unplugged. Most problems are in the wiring. You can also ground the G wire on the back of the gauge and it should also peg the gauge.
Thanks |
