911 gauge/sender matching...
Hello, I am making a custom gauge with some 911 VDO gauge parts and am trying to find the part number for the matching senders to the gauges I have. The two gauges in question are an oil pressure gauge from 0-5 Bar, and an oil temperature gauge with no scale. The oil temp gauge has a white outlined box for cold and a red filled box for hot. I believe these came from a '70-80s 911. I do not have the original gauge body so do not have the standard part number. I can give you the numbers stamped into the actual gauge electronics body.
Oil Pressure - 013056 9.80
Oil temp - 195198 9.80
Thank you for any help you may provide...
Ben Ihas
Old 04-28-2003, 12:47 PM
ben,
this is all i have, hope it helps.
doug waters
doug waters
70 914-6
dougwatersfotos.com
http://www.flickr.com/photos/dougwatersfotos/
Old 04-28-2003, 04:29 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
If you look carefully at the outside edge of the temperature gauge, you will see little tiny numbers. Those are the calibration marks, and they are in degrees C.
Allegedly, the VDO senders with the appropriate range (e.g., 5 Bar pressure sender) work correctly with the 911 gauge modules. I don't know this for a fact, but it is what I have been told.
--DD
Old 04-28-2003, 04:36 PM
OK, on the temp gauge the cold end says 60-90 deg and the red starts at 150 and has another higher mark at 170. What does that tell me?
Old 04-28-2003, 05:05 PM
bernbomb914's Avatar
If you go to the internet look under vdo. there will be vendors listed. call them with your info and they will tell you which sender goes with the guage. their prices are very good also, Ihat,s what I did and they work fine.
Bernie
May all your shifts be true
Chrome Yellow 74 1.8 Beauty
black 74 1.8 project car
2002 Land Rover Disco
2002 Astro Van
32' motor home
Old 04-28-2003, 07:32 PM
PCA7GGR's Avatar
Doug: Great chart - its a keeper!
Sergio
PCA - 36yrs / Ex-RGruppe #197
'04 GT3 Halloween/SF Giants car
'11 E550 Coupe (Königstiger)
Old 04-29-2003, 06:39 AM
5 Bar gauge needs a 80psi sender.
VDO Customer Service - 610-289-1390
Ken
Anything worth doing is worth doing in excess
Every silver lining has a cloud
Assume Nothing
Old 04-29-2003, 07:55 AM
Thanks for all the help! I love this board!!
I called VDO and confirmed that I need the 80PSI sender, which I think has 1/8"-27 NPT threads, part # 360 009. I need to confirm the thread on the temp sender, but if it's 1/8"-27 again the 250 deg sender is # 323 095.
Old 04-29-2003, 10:26 AM
Administrator
170C is 340F. I don't think the 250F sender is the right one... I believe that the threaded bit in the stock sump plate is M14 threads, not NPT.
--DD
Old 04-29-2003, 12:31 PM
The pressure gauge sender will not fit where the pressure switch was without modifing the hole in the sheet metal. You can get a adaptor kit from Pelican to remote mount the sender.
Ken
Assume Nothing
Old 04-29-2003, 12:51 PM
