-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Carb cleaning question (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/1086-carb-cleaning-question.html)
Minh Nguyen 10-16-1999 08:05 PM
Hey you guys out there with carbs. i just got of a pair of used Weber 40's with K&N filters on them. The filters are looking like they could use a bit of a cleaning, and I was wondering if I could get some suggestions on the best and/or cheapest way to bring them back to life. Also, i wouldn't mind hearing about a good way to clean up the carbs themselves. Any kind of input will be greatly appreciated.
thanx,
Minh
JP Noonan 10-16-1999 10:23 PM
K&N makes a cleaning and re-oil kit. Maybe $15. If you don't have the original instructions here are some general rules.
1. DO NOT USE COMPRESSED AIR. It will blow holes in the gauze the filter is made out of.
2. DO NOT USE HARSH CHEMICALS, again it hurts the filter material.
If I remember right you can use mild soap and water, flush the filter with running water from the inside out. Although automatic tranny fluid looks the same as K&N oil, I;m told it is different. Use K&N oil.
Best advise? Buy the kit.
scriabin 10-17-1999 01:57 AM
Yeah. Do not use carb cleaner, or gasoline. Just the soap and water, and a soft paint brush. Rinse it from the inside under the faucet, to push the dirt back out. The Dellorto tech book mentions filter oil first, but says that engine oil in a pan would work, rotating the filter exterior through the oil and then setting it to drain before installation.
--john
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
