-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   1.7L high idle (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/1087838-1-7l-high-idle.html)
dbelden 03-07-2021 07:36 AM
1.7L high idle
I drove my 1.7L 914 last weekend and experienced no problems. This weekend I took it out and it is idling at 4500RPMs. I let it warm up and drove it a couple of miles. The idle would not reset. The throttle cables look fine. I may have a vacuum leak somewhere, but I don't know how to isolate the issue. Any thoughts?http://forums.pelicanparts.com/uploa...1615134905.jpg
http://forums.pelicanparts.com/uploa...1615134958.jpg
TJ-from-NL 03-11-2021 07:46 AM
Carb spray is a good way to isolate vacuum leaks. With engine running, spray it at certain areas. If idle changes, then you've located the leak. Great way to zoom in on a possible vacuum leak
jess p 03-11-2021 12:47 PM
Oil filler cap, intake manifold bolts loose.
Nostril Cheese 03-12-2021 05:33 PM
Timing and carb adjustments is where Id start.
