-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   914 hose routing question (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/1088426-914-hose-routing-question.html)
tonythetarga 03-14-2021 07:44 AM
I am getting ready to put the engine and trans back in the car. It is a '73 1.7 with the stock fuel injection system. I have my fuel lines mapped and routed and understand the flow on the engine side. The fuel pump is in and lines labeled. I installed the unit pictured below, (and I know there is another vacuum attachment that goes above it). What I don't know is what the circled unit is called and what the hose coming off it is connected to. Any insight would be appreciated. I know the electrical connector is on the engine harness and I have that part ID'ed.
http://forums.pelicanparts.com/uploa...1615732957.jpg
bdstone914 03-14-2021 08:32 AM
That is your MPS manifold pressure sensor. It connects to a port on the plenum.
https://bowlsby.net/914/Classic/zTN_FI_Hose_Vac_1.7L_1970-71.jpg
tonythetarga 03-14-2021 10:39 AM
Thanks BD! Appreciate the quick reply.
