Conrad W Peden's Avatar
Steering parts
What is inside the dust boot that attaches to the rack?
Rubber coupling, hard flange....
Pics and cost to replace would be cool.
Thanks guys
We'll be having an ISO9000 audit soon.
I've divided our preparation tasks into two groups: Unethical and Unproductive.
Old 08-09-2004, 04:55 PM
The rack is inside, the boot attaches to the housing that the rack rides in. The rubber eyes (or monoball for Turbo) screw into the ends of the rack.
'80 SC
Old 08-09-2004, 05:13 PM
oops..clarify,
the boot going to the steering column
thanks
Old 08-09-2004, 08:17 PM
You just about nailed it. There's the rubber double thick hockey puck with the holes and bolt sleeves that go through it. And, the two bolt flange on a stick with the splines on the upper end. This stick flange bolts to a similar flange on the housing, with the rubber piece in the middle. I suppose you could replace the rubber "hockey puck" part, but I don't know if they require it or not.
'80 SC
Old 08-09-2004, 09:36 PM
Think i can get to it without taking out the tank? LOL
Didn't think so.
Just trying to diagnose a problem.
Old 08-10-2004, 07:48 AM
I think you need to pull the tank to get to the steering shaft bearing. The steering unit, I believe, is accessible from below.
'80 SC
Old 08-10-2004, 08:48 AM
