Crunch in all gears
I recently rebuilt my 914 and am now having a hard time shifting (more so than when I took the engine out). The gears don't "grind", but frequently it is hard to get it into gear and when it goes it clunks. This happens with all the gears, not just first or second.
Rebuild included lots of things like new clutch, clutch cable, all new shift bushings, new outer firewall and floorpan, etc.
I have adjusted the clutch which helped some, but am suspicious that when I put in the new firewall, the placement of the shift rod bushing might be 1/8" or so off of where it was before. I never disconnected the shift lever assembly so I'm sure it is in the original position.
Any suggestions on how to correct or adjust this? It's a 75 side shifter if that matters.
Old 10-19-1999, 08:09 AM
If you really suspect that you may have thrown off the alignment of the shifter somehow by moving the bushing location, you can "re-align" the shifter as described in the Pelican Tech article on shifting improvements. See http://www.pelicanparts.com/techarticles/914_shift_improve/914_shift_improve.htm under the sub-topic "Shifter Lever". It may be worth a try at least to see if it helps.... but it does sound like more of a clutch problem... hmm... lets us know what you find when you get it straightened out.
- Dave
- Dave
Old 10-19-1999, 08:40 AM
Right now I've got my clutch cable (new) tightened up to the point the fork is hitting against the nut on the trany case when I press in the cluch pedal. Still clunks in all gears, but not as bad. Any other suggestions?
Old 10-20-1999, 12:56 PM
It's been awhile but I recall a similar problem I had after reinstalling my engine and transmission as a complete unit. I found that there is some forward/rearward play in the engine/transmission placement. I had trouble shifting until I moved everything forward or backward...I can't remember which, about a quarter of an inch or some. Voila! everything worked fine after that.
Old 10-21-1999, 04:18 AM
