-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Odometer problem, sort of (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/1101470-odometer-problem-sort.html)
QROtarga 09-02-2021 04:50 PM
About 3 years ago i purchased a nicely rebuilt speedometer in Germany, to substitute the one on my 914 which was failing. It worked great until recently, when the odometer stiopped working, but only at high temperatures. After cooling down, it workes well again.
I guess that somewhere between the cable and the number wheels something is slipping at higher temperatures and sticks again at lower temperatures.
Any ideas how to deal with this, without opening the speedometer (wishful thinking, as I have done this on VDO instruents before for other checks and I really didn't like it)?
The odometer is of great use for me, as my 914 is an electric conversion, and the odometger is a good help for determining the charge left before needing to recharge the batteries.
Harald
Dave at Pelican Parts 09-02-2021 10:08 PM
It's probably the pot-metal gear inside the odometer mechanism slipping on its shaft. If you let it go, eventually the odometer will completely stop.
Here's the tech article on dealing with it (and a few other problems):
https://www.pelicanparts.com/techarticles/Mult_gauge_repair/mult_gauge_repair.htm
--DD
QROtarga 09-07-2021 04:13 PM
Thanks Dave!
With cooler temperatures ahead, I will have a look at this next spring!
Schafer49 09-22-2021 02:19 AM
--DD
Thanks, very impressive. Really I appreciate for such a helpful information.
