-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Engine Serial # CA012986X (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/110220-engine-serial-ca012986x.html)
HP is good 05-10-2003 07:17 PM
I removed an engine from a '72 914 and the serial number next to the oil filler is CA012986X. Does anyone know what this is? The engine is currently on ebay. It's definatly CA and not GA.
-Todd
bowlsby 05-10-2003 10:15 PM
Google on vw engine codes says ...
"CA 49 Kw 66 Hp 1679 cc 2 08/'71>07/'73"
Its a bus motor if you are sure its not a GA code.
ratwell 05-10-2003 11:52 PM
The serial number seems valid for that short lived engine but the X at the end confuses me. If it was a VW of Canada remanufactured engine it would have had a sticker with a new number on it so that number is peculiar.
Dave at Pelican Parts 05-11-2003 10:14 AM
According to http://www.tunacan.net/t4/reference/case.htm , it's a 1.7 engine that made 66 HP. No other information is available, but it came from some VW-badged vehicle. (Probably a Bus, from the post above some particular CA-spec Bus?)
--DD
