Turn signal return
Hi all. I'm a new owner of a '74 914 2.0, getting familiar with the car and fixing some minor problems. Currently the turn signal does not automatically shut off after completing a left or right turn. It should do that, right? Looking at a Haynes manual, it appears the culprit is the steering column switch. Are these available or would the switch I have need to be rebuilt? Thanks!
Old 01-12-2022, 06:45 AM
Cairo94507's Avatar
Welcome to 914 ownership. The absolute best place to get 914 advice and find parts is 914World.com. Go there and introduce yourself and post some pictures of your car and you will get all the info and help you need to keep your 914 running and make it as nice as you want.
'71 914-6 #0372
'17 Macan GTS
Old 01-12-2022, 08:02 AM
cajones's Avatar
Google this string, lots of good results: "site: www.914world.com turn signal cancel"
There are a couple things it could be--the ring on the back of the wheel, or it's positioning, also the switch and the little nub that it has that the cancelling ring contacts to reset to neutral... those links will have detailed pics
Old 01-13-2022, 02:53 PM
Thanks cajones, that's exactly what I needed. I did find a replacement turn signal switch at Sierra Madre parts for what seems like a reasonable price, but eliminating the other potential causes is the first order of biz. Doug
Old 01-13-2022, 04:30 PM
