Weird 914 starter problem
Here's a weird one that maybe somebody has an idea about:
My 914 runs great but about every 3 or 4 days, and after many normal starts, I turn the
ignition and I hear only a dull click from down at the starter. Here is the strange part: When this happens I can put the car in 5th gear roll it back slightly to turn the engine a bit, and it fires right up. Anyone had this happen? Thanks Dan
Old 02-23-2022, 11:51 PM
Could be a ‘dead spot’ on starter armature. Also, make sure you clean the ground connector on the battery and at the transmission.
Old 02-24-2022, 03:00 AM
Could also be a bad spot on the flywheel. Rolling the car in 5th gear rotates the flywheel to a "clean spot" where the starter drive gear can fully engage the flywheel and start things turning. If its a '74 and you haven't bypassed the "seatbelt/starter safety interlock" (as recommended by the factory) you may be getting random weak current to the starter solenoid.
Old 02-24-2022, 06:13 AM
Emo993's Avatar
I'm with tony, dead spot...
1974, 914-6 GT Tribute
2007 Cayman S
1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten.
2017 Golf Sportwagon 4motion
Exclusive source for the 914 Umbrella and Service cover
Old 02-24-2022, 01:06 PM
