-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   rear wheel hub spacing problem (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/1113970-rear-wheel-hub-spacing-problem.html)
roadsportusa 03-04-2022 07:17 AM
I am running a hybird rear hub. 4 bolt converted to 5 bolt.
Vented rotors from rear 911
M calipers
having a rotor spacing problem
need to space rotor out from hub surface about 4 mm
Does anyone sell a flat spacer to fit behind rotor mounting surface??
Fly Mach .86 03-06-2022 06:42 PM
I'm not sure if anyone makes a spacer but if you have a machine shop nearby, you might get them to make some for you. Why do you need a spacer? Is it rubbing/interfering with something?
Cheers, Elliot
Emo993 03-07-2022 04:33 AM
Roadsportusa, I made spacers for my standard rear five bolt hubs when I put 914 front calipers on the rear. I have two thickness, 4.2 and 6.2mm. Not sure which one's I used, car still in storage.'Just use thin washers as spacers to find the exact size, draw out a template and take to a machine shop as Elliot said. Best, Mark, just read your post again, you want to space out rotor, not caliper?http://forums.pelicanparts.com/uploa...1646656382.jpg
djpateman 03-12-2022 07:10 PM
Yes, I have a few sets of those spacers.http://forums.pelicanparts.com/uploa...1647140973.jpg
the big rings here
