-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   3K idle and wouldn't go down, what's going on? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/1116617-3k-idle-wouldnt-go-down-whats-going.html)
Zola 04-10-2022 03:06 PM
Driving yesterday in California it was a hot 90F+ day. My '76 FI drove fine for grocery run. On way home, out of the blue, she stalled at stoplight. Did a very hard start with gas pedal mashed to floor, finally started up and she never idled below 3K from then on, I looked down and oil temp. gauge was dead...Drove about 5-10 more minutes to get home...After letting things cool down, hours later I went out to start and idle still very high 2.5K to 3K and won't come down....oil gauge is working again...WTF is going on?
Zuffenwerker 04-10-2022 05:57 PM
Throttle linkage hanging up on something?
Daniel
tonythetarga 04-11-2022 03:21 AM
Sounds like a vacuum leak. Check the hoses.
Dave at Pelican Parts 04-11-2022 01:44 PM
Two main things could cause a high idle.
1 - more air going into the intake
2 - ignition timing over-advanced
For 2, check your timing. Dig out a timing light and our Tech Article on the procedure and have at it.
For 1, the first thing to do is look for hoses that have fallen off. This seems like the most likely cause of a very sudden air leak. Next, try moving the throttle valve and see if it does close smoothly.
--DD
