kill switch, ballast resistor install msd ign.
After installing the MSD 6A on the 3.0 I had the run on problem, which I also had on my 914 4 I have the ballast resistor I think the red switched wire attaches to it and a ground on the other side, do i also run another wire to the switched source. Also I would like to install a kill switch could I run a wire from my switch to the coil and what pole + or -.
David |
Describe the run on problem....do you mean it runs on after you switch off power?
Yes, power is bleeding back into the system via alternator idiot light wire. I know i may need to solder a diode in the line, I have a ceramic chrysler diode but its been so long since it was hooked up i need a little help sorting it all out.
David |
I had the same run-on issue when I installed an Electromotive HPX unit. I placed the diode in-line between the voltage regulator and the charging light. Problem fixed and have not had any issues since. I think page 7 of the MSD installation manual details the diode installation, online version of manual is at http://www.msdignition.com/
I have the multi-pole kill switch connected to the ignition's main power supply wire. |
| All times are GMT -8. The time now is 02:25 AM. |
