synthesis's Avatar
911 oil gauge in 914
I would like to replace the speedo in my racecar with the 911 oil pressure, temp combo. Is this swap easy to do? What is involved with the sensors etc?
thanks,
dr
Old 05-23-2003, 01:13 PM
Senders should be the same. You want the 5 bar pressure sender and the standard temp sender that mounts into the taco plate-I think it's a 350F sender but could be wrong.
Old 05-23-2003, 01:14 PM
