Sloppy Tach
My tach is really bouncy/sloppy, is this normal, or do I need a replacement?
2011 Chevy Silverado (The Hauler)
1984 911 Carrera summer daily driver
Old 05-28-2003, 09:20 AM
Mine too! Sometimes it's fine, other times it's bouncing all over the place, mostly while at speed. I haven't looked into it yet but was figuring on checking grounds. Also my distibutor's noisy (squeaky) and has a fair amount of wobble so I wonder if that has to do with it.
Ed
'74 914 V8
'70 914
Old 05-28-2003, 10:59 AM
Ornery Bastard
Tach is driven by the ignition points. If the tach is sloppy when not shifting (i.e. it bounces with no apparent reason) then you need new points.
If the tach bounces a lot between shifts (i.e. a lack of damping) then the inside of the tach is probably dirty and you can either have your current tach cleaned or get another tach.
Aaron
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 05-28-2003, 11:07 AM
Kenny Powell's Avatar
sometimes if the planets are allighned proper you can clean the contact for tach at the coil, it has worked for me before!
75' 2.0 w Ljet
"I like the way she doesn't move in the curve's... and then she let's go!"
Old 05-28-2003, 11:51 AM
Many times you have to chop off the old connector and crip on new one... as well as clean the posts. You'll notice the copper wire starts to corrode... and with heat, connectivity decreases... so you'll get more bouncy when the engine is warm.
74-1.8 (sold)
86-944 turbo (sold)
97-M3 coupe (sold)
03-M3
http://www.pelicanparts.com/gallery/castlesteve/
Old 05-28-2003, 12:53 PM
