Bride of Rubber Fuel Pump Mounts
Well, I need new rubber mounts for my fuel pump. New ones are awfully steep ($22 ea). Have any of you fabricated these to your satisfaction? If so, how?
I’m primarily worried about two things: vibration against the sheet metal and air circulation around the critter. (I assume this aids in cooling the pump; my pump is mounted in the original location, right & forward of the engine.) So I’d like to spec out the new mounts as closely to the originals as possible. I no longer have the originals, by the way. Cosmetics are not important. Any comments or ideas?
Mark 1971 1.7l 914 |
Air cleaner (air filter housing) mounts from some older Mercedes cars (70's S class with CIS) are very similar and cost only $1.50 each.
any VW place will have similar ones for low $$$
AKA: Dr Evil on the 914World forum, need your tranny rebuilt, or want a "How to rebuild your transmission DVD" set? PM me. -74 914 with 74 2.7 CIS -74 VW Bus with modified 3.1 corvair engine and 3.0 CIS fuel injection system. -74 BMW R90 |
Thanks for the replies. You're right, the local ******** has something that'll work perfectly for a lot less.
You can get isolators from www.mcmaster.com for a couple of buck each, quite a variety available too.
John Yellow '76 914 3.2 YPAF |
